Trek 8500
Trek 8500
Сообщение 03 мар 2013, 17:03
Frame: Trek 8500 2012 Alpha Red Platinum Aluminum 18,5".
Fork: Rock Shox SID XX 2013, XLoc, Black, 100 mm travel.
Headset: FSA Orbit Z, 1-1/8" threadless, semi-integrated, semi-cartridge bearings.
Buttom bracket: Truvativ GXP Press Fit BB92, 89,5x41 mm.
Steam: Deda Zero100 AL2014 3D forged, white 80 mm, 8°.
Spacers: Bontrager carbon, 1x10mm.
Handlebar: Procraft Pro 720TF OS Flat, 720 mm, backsweep 9°.
Grips: Ritchey WCS Truegrip foam grips 2013, black.
Seatpost: Thomson elite 367 mm, zero offset, black.
Seatpost clamp: Bontrager alloy bolting black.
Saddle: Selle San Marco aspide racing Team 2012, Manganese rails.
Rear derailleur: XT M8000GS Shadow+ 11 Speed, medium cage, black.
Front derailleur: not present.
Gearshift: XT M8000, 11 Speed Trigger, I-Spec II, right shifter only.
Outer gear casing: Alligator White, 1500 mm.
Cassette: XT M8000, 11 Speed cassette, 11-42.
Chain: Shimano HG600, HGX 11 Speed chain, 110 links.
Chainlock: Not present.
Crankset: Truvativ X.9 GXP, black, 175 mm.
Chainring: Garbaruk Narrow wide, 34T, Red, Direct mount Sram GXP .
Pedals: Shimano M540 SPD, silver.
Brakes levels: Shimano XT M8000, black, I-Spec II.
Callipers: Shimano XT M785 disc black.
Brake hose: Shimano BH90.
Brake pads: China metal.
Rotors: Front/Rear, Shimano XT RT81, Сenter lock, 160 mm.
Hubs: Deore XT M785 Black 32H, Front 5x100mm, Rear 5x135mm.
Spokes: DT Swiss Competition Silver 2.0-1.8-2.0 (264 mm 32H), (262 32H).
Nippels: DT Swiss, alu, silver 14G 12mm.
Rims: ZTR Crest White 32h.
Tubeless ventil : NoTubes Presta 35mm.
Rim tape: NoTubes 25 mm Yellow tape.
Sealant: NoTubes Tire Sealant.
Tires: Front/Rear, Schwalbe Racing Ralph Evo Tubeless Ready 26x2,25''/Geax Saguaro TNT 26x2,2''.
Weight: 10,59 kg.
Оффтоп: Еще фото
Последний раз редактировалось meisterkirill 03 мар 2016, 15:50, всего редактировалось 72 раз(а).
meisterkirill
24 ноя 2011, 18:37
Мой байк: 29er trailbike
Re: Trek 8500
Сообщение 03 мар 2013, 17:30
несколько удивляет сочетание топовых и уг компонентов на одном веле...
что особо режет глаз: седло/подседел, тормоза с роторами, непиленный шток вилки. Руль и педали на любителя, но если удобно... Подрамная сумка на гоночной раме - это йад *buee* :D
Колеса рабочие, но устарели лет на 5 *sorry*
Рама+вилка и трансмиссия ХТ диктуют более высокий уровень для всей остальной навески, так что я думаю все ещё будет меняться ;)
Re: Trek 8500
Сообщение 03 мар 2013, 17:45
корсак писал(а):несколько удивляет сочетание топовых и уг компонентов на одном веле...
Конечно, Денис, все будет в скором времени меняться :) Педали недешевые, они удобные, я не перейду на контакты принципиально *sorry* Шток я и так отпилил, не хочу больше потому что потом думаю будет проще продать, мне спейсеры не мешают :)
Колеса я брал три с половиной года назад с пробегом 500 км у Алексеича, тогда они были хороши. Пока я эти втулки не укатаю менять не буду ;)
meisterkirill
24 ноя 2011, 18:37
Re: Trek 8500
Сообщение 03 мар 2013, 17:56
зачем продавать эту вилку? разве есть что-то лучше? ;)
Re: Trek 8500
Сообщение 03 мар 2013, 18:00
AtMatt писал(а):зачем продавать эту вилку? разве есть что-то лучше? ;)
Да нет конечно, это вилка супер!!! Та ладно, подумаю, обрежу)
meisterkirill
24 ноя 2011, 18:37
Re: Trek 8500
Сообщение 03 мар 2013, 18:02
meisterkirill писал(а): Пока я эти втулки не укатаю менять не буду ;)
тогда это навечно :D
резину только смени ашанскую ;)
Re: Trek 8500
Сообщение 03 мар 2013, 18:11
Сменю!
meisterkirill
24 ноя 2011, 18:37
Re: Trek 8500
Сообщение 03 мар 2013, 18:15
Последний раз редактировалось DELETED 25 апр 2013, 21:49, всего редактировалось 1 раз.
Re: Trek 8500
Сообщение 03 мар 2013, 18:23
Да и тормоза ....... бюджетная шимановская механика!!! Много того , что рядом как-то на смотрица ;)
Re: Trek 8500
Сообщение 03 мар 2013, 18:26
ghost писал(а):Да и тормоза ....... бюджетная шимановская механика!!! Много того , что рядом как-то на смотрица ;)
Знаю, знаю)
meisterkirill
24 ноя 2011, 18:37
